Hi there! My class has a set of VEX IQ 1st gens. When I try to connect, either via USB to my macbook air, or by bluetooth on a dell notebook or my macbook, no device is detected. I tried installing a driver on the Dell.
Does anyone any ideas?
Thanks!
You can find info here: https://kb.vex.com/hc/en-us/articles/5853657619476-Get-Started-with-VEX-IQ-1st-generation-
Do you have the current version of VEXCode IQ on both your macbook and your Dell?
You mentioned installing a driver on the Dell. What driver? The VEX drivers should install when you installed VEXCOde IQ
For USB connection, you need to make sure that the cable is a USB data cable. Some cables are for charging only.
Thanks for responding,
I have only been trying to use the we- based codeiq.vex.com: I don’t have any programs downloaded. CodeIQ doesn’t run on ipads, you need the app installed. I can’t update my ipads without district support (which I’ve requested).
When you access the site using the Dell, a driver download window pops up, so I tried installing that. Still nothing.
Frustrating.
You can only use Bluetooth on tablet devices. Chromebooks and notebooks etc would be USB only.
