Hi, I am trying to figure out why this robot code won’t execute – it seems to “skip” the first set of commands.
I am attempting to have a robot (EDR Vex Cortex) that sees an obstacle a certain distance away, and then stops, turns, and goes forward. But for now I just wanted something that responds to the sensor.
In any case this is what I have, using Vex 2.0 Cortex Natural Language.
I tried putting a repeat(forever) at the start, and it went to the first line and repeated – but didn’t execute any other code.
#pragma config(Sensor, dgtl4, echo2, sensorSONAR_cm)
#pragma config(Motor, port1, rightMotor, tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port10, leftMotor, tmotorVex393_HBridge, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
setMotor(port1, -60);
setMotor(port10, 60);//turn to left
wait(1);
stopMotor(port1);
stopMotor(port10);
setMotor(port1, 60);
if(SensorValue[echo2] <=25)
{motor[port1] = 0;
motor[port10] = 0;}
else
{motor[port1]=60;
motor[port10] = 60;}
resetSensor(echo2);
Anyhow, help might be appreciated – maybe resetting the sensor was the problem? But the Robot C wizard tells me it doesn’t even get there.
Thanks
