trying to programme
I know that telop = driver controlled adapted to our own needs. I can t seem to get it going. The motors and sensors are attached. I’ve inputted into RObot C correct code to change speed of motors to 50% but no budge at all.
How do I get code working under Tel op.
Seems to be okay under Autonomous.
Many thanks,
Mary
Hello Maire,
Thank you for visiting out forum.
It sounds like there might be an issue with your motors, can you see if you can run the motors in teleop using the “Driver Control” menu on the IQ Brain?
All you have to do is select on the brain: Driver Control> Run
Then you will be able to control the motors with your IQ Controller.
Let me know your results.
