Hi so I recently tried to make a PID and I did some research and tried to make one and I think I actually have a PID but something is wrong with it. The pid never stops even when the sensors or encoders will go past the target value and the drive pid is super fast while the turning one is so slow it wont move.
anyways here is the code
Drive_Gear_Ratio = (36/48)
max_speed = 100
min_speed = 20
error = 0
integral = 0
derivative = 0
previous_error = 0
kp = .2
ki = .2
kd = .2
kf = 5
def drive_distance(target_distance):
global error, integral, derivative, previous_error
# Reset PID variables
error = 0
integral = 0
derivative = 0
previous_error = 0
# Main PID loop
while True:
current_distance = ((3.14159265 * Wheel_Diameter) / 360) * (LeftDrive1111_motor_a.position(DEGREES)) * (Drive_Gear_Ratio)
error = target_distance - current_distance
integral = integral + error
derivative = error - previous_error
output = kp * error + ki * integral + kd * derivative
feedforward = kf * target_distance
speed = max(min_speed, min(max_speed, feedforward + max_speed - abs(output)))
left_speed = speed
right_speed = speed
if error < 0:
left_speed *= -1
right_speed *= -1
LeftDrive1111.set_velocity(left_speed, PERCENT)
LeftDrive1155.set_velocity(left_speed, PERCENT)
RightDrive1111.set_velocity(right_speed, PERCENT)
RightDrive1155.set_velocity(right_speed, PERCENT)
previous_error = error
wait(20, MSEC)
# Break the loop when close enough to the target
if abs(error) < 1:
break
LeftDrive1111_motor_a.set_velocity(0, PERCENT)
LeftDrive1155_motor_a.set_velocity(0, PERCENT)
RightDrive1111_motor_a.set_velocity(0, PERCENT)
RightDrive1155_motor_a.set_velocity(0, PERCENT)
def turn_to_angle(target_angle):
error = 0
integral = 0
derivative = 0
previous_error = 0
# Main PID loop for turning
while True:
current_angle = inertial_10.heading(DEGREES)
error = target_angle - current_angle
feedforward = kf * target_angle
left_speed = -speed
right_speed = speed
LeftDrive1111_motor_a.set_velocity(left_speed, PERCENT)
LeftDrive1155_motor_a.set_velocity(left_speed, PERCENT)
RightDrive1111_motor_a.set_velocity(right_speed, PERCENT)
RightDrive1155_motor_a.set_velocity(right_speed, PERCENT)
# Update previous error
# Sleep for a short time to avoid excessive loop execution
wait(20, MSEC)
# Break the loop when close enough to the target angle
if abs(error) < 1:
break
RightDrive1155_motor_a.set_velocity(0, PERCENT)```
I honestly think I just screwed up how I calculated some things but i'm too stupid to figure out how to fix it. Any help is appreciated I have a tourney this weekend and I really need some win-points.
