I’m trying to run a code with a quad encoder but when i turn on the autonomous all it does is go forward till i turn off the autonomous . What am i doing wrong?
#pragma config(Motor, port1, , tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port2, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port3, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port5, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port9, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port10, , tmotorVex393_HBridge, openLoop)
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(15)
#pragma usercontrolDuration(120)
#include “Vex_Competition_Includes.c” //Main competition background code…do not modify!
// Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
wait1Msec(2000); //Two second Delay
SensorValue[dgtl1] = 0; //Clear the right encoder value
SensorValue[dgtl3] = 0;
SensorValue[dgtl5] = 0;//Clear the left encoder value
//While the encoders have spun less than 3 rotations...
//while(SensorValue[dgtl1] < 1080)
//Move Forward
//motor[port8] = 63;
//Stop for half a second
//motor[port8] = 0;
//wait1Msec(500);
// All activities that occur befo re the competition starts
// Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
// Insert user code here.
// port 1,5,6 is the right
// port 3,4,10 is the left
while(SensorValue[dgtl1] < 300 || SensorValue[dgtl3] > -300)
motor(port10)= - 170;
motor(port3)= - 170;
motor(port4)= - 170;
motor(port1)= 170;
motor(port5)= 170;
motor(port6)= 170; // still get the same distance.
wait1Msec(500);
motor(port10)= 0;
motor(port3)= 0;
motor(port4)= 0;
motor(port1)= 0;
motor(port5)= 0;
motor(port6)= 0;
wait1Msec(500);
motor(port8)=-127;//shoot at high right flag
wait1Msec(1300);
motor(port8)=0;
while(SensorValue[dgtl1] > 0 || SensorValue[dgtl3] < 0)
motor(port1)= 170;
motor(port5)= 170;
wait1Msec(500);
motor(port10)= 0;
motor(port3)= 0;
motor(port4)= 0;
motor(port1)= 0;
motor(port5)= 0;
motor(port6)= 0;
wait1Msec(500);
while(SensorValue[dgtl1] > -1750 || SensorValue[dgtl3] < 1750)
motor(port10)= 170;
motor(port3)= 170;
motor(port4)= 170;
motor(port1)= - 170;
motor(port5)= -170;
motor(port6)= -170; // still get the same distance.
wait1Msec(500);
motor(port10)= 0;
motor(port3)= 0;
motor(port4)= 0;
motor(port1)= 0;
motor(port5)= 0;
motor(port6)= 0;
wait1Msec(500);
while(SensorValue[dgtl1] > 350 || SensorValue[dgtl3] <-350)
motor(port10)= 170;
motor(port3)= 170;
motor(port4)= 170;
motor(port1)= 170;
motor(port5)= 170;
wait1Msec(500);
motor(port10)= 0;
motor(port3)= 0;
motor(port4)= 0;
motor(port1)= 0;
motor(port5)= 0;
motor(port6)= 0;
wait1Msec(500);
while(SensorValue[dgtl1] > 2500 || SensorValue[dgtl3] <2500)
motor(port1)= 170;
motor(port5)= 170;
wait1Msec(500);
motor(port10)= 0;
motor(port3)= 0;
motor(port4)= 0;
motor(port1)= 0;
motor(port5)= 0;
motor(port6)= 0;
wait1Msec(500);
// User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
{ while (1==1)
motor(port10)= -vexRT[Ch2]; // port 1 is the front right driver
motor(port3)= -vexRT[Ch2]; // port 2 is the back right driver
motor(port4)= -vexRT[Ch2]; // port 9 is the front left driver
motor(port5)= vexRT[Ch3];// port 10 is the back left driver
motor(port6)= vexRT[Ch3];// port 10 is the back left driver
motor(port1)= vexRT[Ch3];// port 10 is the back left driver
if(vexRT[Btn6D] == 1) // if button 6u is pressed lift goes up
motor(port8)= 0;
else if(vexRT[Btn6U] ==1) // if button 6d is pressed lift goes down
motor(port8)= -127;
else // if nothing is pushed...
motor(port8)= 0;
if (vexRT[Btn5D] ==1) //if button 8r is pressed elevator goes up
motor(port7) = -127;
else if (vexRT[Btn5U] ==1) // if button 8d is pressed elevator goes down
motor(port7) = 127;
motor(port7) = 0;
if(vexRT[Btn7U] == 1) // if button 5u is close claw
motor(port2)= -127;
else if(vexRT[Btn7D] ==1) // if button 5d is pressed open claw
motor(port2)= 127;
motor(port2)= 0; // nothn happens
if(vexRT[Btn8U] == 1) // if button 5u is close claw
motor(port9)= -127;
else if(vexRT[Btn8D] ==1) // if button 5d is pressed open claw
motor(port9)= 127;
motor(port9)= 0; // nothn happens
