For some odd reason, the motors on our drive base twitch whenever I drive forward, back, turning. They go in short spasms. But whenever we pick the robot off the ground and drive, it works fine, the motors run smoothly. It is only when the robot is on the ground that it twitches.
We also have a lift mechanism attached to the claw on top of the robot.
We’re not sure if its a programming issue or a mechanical issue. Maybe the lift system is too heavy, but I’m not sure if that will affect the drive.
it does sound like a torque problem considering they work fine when the robot is lifted. How heavy is your robot and what ratio do you have? because it may be too much even for the high strength motors, or something maybe short circuiting?
Our gear ratio is 60:36. Do you recommend that I try the 84:60 gear ratio w/ the high-torque motors or have 1 standard motor connecting to each of the 4 wheels?
Currently, I do not know the exact weight of the robot, but I estimate it to be around 10 pounds-ish.
Sorry, i dont understand what you are saying. But i would recommend trying direct drive and if the twitching is still there, it wont be torque. How many motors do you have driving it at 60:36?
ok, good luck! let us know if it works or not. We had a 84:60 ratio earlier in the season with 2 HS motors on speed and it burnt them out, so i think that 60:36 is a bit much anyway. Oh, and your code looks fine to me
You said you have Y cables on the wheel motors, but not on the arms, right?
You could try converting from tank2 to tank4, with no Y cables on the wheel motors, and put the Y cables on the arm motors instead.
Chris is me: yes, we are using 4" wheels. We’re planning on keeping the 4" wheels but going with direct drive, one motor per wheel. The motors get warm but not extremely hot.
In general, if your motors are “twitching” (stalling) they’re overloaded. You can fix this by adding more motors, reducing the gear ratio (what you are doing now), or by lightening your robot. The configuration you’re describing is gearing your robot for about 2.8 feet per second, or a very fast speed for an average Vex robot. It can be done but it requires careful engineering and the use of more than one motor per side of the drivetrain.
