Two controllers. one brain? (New)
So, we are using two controllers for our competition, and I can not get them to pair? I’ve tried to connect them both separately, as well as connecting them together then connect one to the brain. Any suggestions? (This is also within pro but that shouldn’t have an effect.)
As what I am aware of:
Pair one of the controller to the brain and that is the main controller. The secondary controller is to be tethered to the primary controller. You can add two controllers in the motor and sensor setup on the V5 brain.
Wire the controllers together and connect to brain
I have tried this, though I thank you for the response. That didn’t work either, and I’m almost starting to think that the controller is just dead.
It works on and off, and whenever we plug in that specific controller into the computer, the firmware is unavailable. I think the controller itself may not work, but I will try today to see if other controllers work. If so, it’s the controller itself; we’ve tried multiple wires and cords.
