I have a pretty heavy roller intake that I want to lift. Hitherto, I planned on using rack and pinion lifts, but what other types of lifts would be viable options? Thank you in advance.
The most generic design is the double reverse with an additional mini four bar to internally stack. This allows the best way to internally stack as of right now. Other options for a lift can differ depending on how much you want to experiment and work with. If you want it easy, a chain bar wound be fine to stack small series of cones. Other options can be the four bar and six bar (don’t really recommend) and another option is a ripper style lift that can be seen in RI3D reveal. Hope this helps!
I have some small rollers on my chain bar, and it gets 3 cones easily. I also have a 4bar MG lift on the other side.
