We have some old VEX sets here in our lab. I’d like to repurpose an ultrasonic sensor for this project using an Arduino:
Does anyone have any advice on how I can use it with the board? I understand that the black wire = ground and red = 5V, but I’m not sure how to interpret the output from the 3rd wire. In addition, I’m not sure if I can just one of the two sensors that come on the board.
So assuming you are using a Vex ultrasonic sensor it is actually 1 sensor that uses 2 digital ports not analog.
You flip the input wire high and time how long it takes before the output wire goes high. Then convert to inches etc. I suggest using the second pin on an interrupt port to get accurate timing.
I made an arduino library here for running a Vex ultrasonic sensor.
One thing being that the library was designed for several sensors to all share a single interrupt port. And allowed 5 sensors to run off of only 5 digital output and 1 interrupt instead of 10 ports total. This isn’t important for your project but it will explain why it is organized the way it is.
