ultrasonic sensor times out
Hi,
I am using the ultrasonic test program included with EasyC 4 (4.0.1.1) with the Cortex microcontroller (with latest master code).
I am getting the error message
“Ultrasonic sesor [sic] on echo port 1, ping port 11 timed out, check the connections”
I have tried:
-plugging and unplugging connections to the sensor
-using a different set of digital I/O ports
-switching the wires between port 1 and 11
-switching the ultrasonic sensor (tried with all three available sensors)
-switching the cortex microcontroller for another cortex microcontroller
In all cases, the same error was given. Only once did I receive a different error, but i was unable to repeat this. (The other error was “out of range”.)
Any thoughts on why I might be seeing this error and what I can do to fix it?
Thanks!
:slight_smile: jen
