Does anyone know how to program a ultrasonic sensor with v5 if so do you have the code
You are looking for the Sonar class. It’s pretty easy to use. Set it up with the device panel in Robot Mesh Studio on one of the 3-wire ports (it can only go on A, C, E, or G then also takes up B, D, F, or H for the second wire). Ask for the range with the
distance
method. You can give it a
DistanceUnits
as an argument, otherwise it will return the distance in mm.
The above code is still private
John- can you please share the code for v5
Sorry about that. It’s public now.
