The title says it all. I have made some very basic code in vs code using PROS and the code refuses to build or upload. No errors are sent when I try to build, but it gives the error “NOERROR” when i try to directly upload. Any help is appreciated. Thanks.
Are you using the PROS Extension, along with the CLI, and tool chain? Also are you using the buttons or the terminal? Sometimes the buttons don’t work properly, however just use “pros mu” in the terminal to make/build and upload code to a V5/Cortex Brain.
Ok, did you open just main.cpp? If so, you need to open the whole project. It should be an entire folder with your project name that you are opening.
