We encountered a strange error while programming
This is what the error is:
[info]: Saving Project ...
[info]: Project saved!
windows build for platform vexv5
vex/mkrules.mk:23: warning: overriding recipe for target 'build/Gearbots'
vex/mkrules.mk:17: warning: ignoring old recipe for target 'build/Gearbots'
make: Circular build/Gearbots <- build/Gearbots dependency dropped.
Usage: arm-none-eabi-objcopy [option(s)] in-file [out-file]
Copies a binary file, possibly transforming it in the process
The options are:
-I --input-target <bfdname> Assume input file is in format <bfdname>
-O --output-target <bfdname> Create an output file in format <bfdname>
-B --binary-architecture <arch> Set output arch, when input is arch-less
-F --target <bfdname> Set both input and output format to <bfdname>
--debugging Convert debugging information, if possible
-p --preserve-dates Copy modified/access timestamps to the output
-D --enable-deterministic-archives
Produce deterministic output when stripping archives
-U --disable-deterministic-archives
Disable -D behavior (default)
-j --only-section <name> Only copy section <name> into the output
--add-gnu-debuglink=<file> Add section .gnu_debuglink linking to <file>
-R --remove-section <name> Remove section <name> from the output
-S --strip-all Remove all symbol and relocation information
-g --strip-debug Remove all debugging symbols & sections
--strip-dwo Remove all DWO sections
--strip-unneeded Remove all symbols not needed by relocations
-N --strip-symbol <name> Do not copy symbol <name>
--strip-unneeded-symbol <name>
Do not copy symbol <name> unless needed by
relocations
--only-keep-debug Strip everything but the debug information
--extract-dwo Copy only DWO sections
--extract-symbol Remove section contents but keep symbols
-K --keep-symbol <name> Do not strip symbol <name>
--keep-file-symbols Do not strip file symbol(s)
--localize-hidden Turn all ELF hidden symbols into locals
-L --localize-symbol <name> Force symbol <name> to be marked as a local
--globalize-symbol <name> Force symbol <name> to be marked as a global
-G --keep-global-symbol <name> Localize all symbols except <name>
-W --weaken-symbol <name> Force symbol <name> to be marked as a weak
--weaken Force all global symbols to be marked as weak
-w --wildcard Permit wildcard in symbol comparison
-x --discard-all Remove all non-global symbols
-X --discard-locals Remove any compiler-generated symbols
-i --interleave [<number>] Only copy N out of every <number> bytes
--interleave-width <number> Set N for --interleave
-b --byte <num> Select byte <num> in every interleaved block
--gap-fill <val> Fill gaps between sections with <val>
--pad-to <addr> Pad the last section up to address <addr>
--set-start <addr> Set the start address to <addr>
{--change-start|--adjust-start} <incr>
Add <incr> to the start address
{--change-addresses|--adjust-vma} <incr>
Add <incr> to LMA, VMA and start addresses
{--change-section-address|--adjust-section-vma} <name>{=|+|-}<val>
Change LMA and VMA of section <name> by <val>
--change-section-lma <name>{=|+|-}<val>
Change the LMA of section <name> by <val>
--change-section-vma <name>{=|+|-}<val>
Change the VMA of section <name> by <val>
{--[no-]change-warnings|--[no-]adjust-warnings}
Warn if a named section does not exist
--set-section-flags <name>=<flags>
Set section <name>'s properties to <flags>
--add-section <name>=<file> Add section <name> found in <file> to output
--rename-section <old>=<new>[,<flags>] Rename section <old> to <new>
--long-section-names {enable|disable|keep}
Handle long section names in Coff objects.
--change-leading-char Force output format's leading character style
--remove-leading-char Remove leading character from global symbols
--reverse-bytes=<num> Reverse <num> bytes at a time, in output sections with content
--redefine-sym <old>=<new> Redefine symbol name <old> to <new>
--redefine-syms <file> --redefine-sym for all symbol pairs
listed in <file>
--srec-len <number> Restrict the length of generated Srecords
--srec-forceS3 Restrict the type of generated Srecords to S3
--strip-symbols <file> -N for all symbols listed in <file>
--strip-unneeded-symbols <file>
--strip-unneeded-symbol for all symbols listed
in <file>
--keep-symbols <file> -K for all symbols listed in <file>
--localize-symbols <file> -L for all symbols listed in <file>
--globalize-symbols <file> --globalize-symbol for all in <file>
--keep-global-symbols <file> -G for all symbols listed in <file>
--weaken-symbols <file> -W for all symbols listed in <file>
--alt-machine-code <index> Use the target's <index>'th alternative machine
--writable-text Mark the output text as writable
--readonly-text Make the output text write protected
--pure Mark the output file as demand paged
--impure Mark the output file as impure
--prefix-symbols <prefix> Add <prefix> to start of every symbol name
--prefix-sections <prefix> Add <prefix> to start of every section name
--prefix-alloc-sections <prefix>
Add <prefix> to start of every allocatable
section name
--file-alignment <num> Set PE file alignment to <num>
--heap <reserve>[,<commit>] Set PE reserve/commit heap to <reserve>/
<commit>
--image-base <address> Set PE image base to <address>
--section-alignment <num> Set PE section alignment to <num>
--stack <reserve>[,<commit>] Set PE reserve/commit stack to <reserve>/
<commit>
--subsystem <name>[:<version>]
Set PE subsystem to <name> [& <version>]
--compress-debug-sections Compress DWARF debug sections using zlib
--decompress-debug-sections Decompress DWARF debug sections using zlib
-v --verbose List all object files modified
@<file> Read options from <file>
-V --version Display this program's version number
-h --help Display this output
--info List object formats & architectures supported
arm-none-eabi-objcopy: supported targets: elf32-littlearm elf32-bigarm elf32-little elf32-big plugin srec symbolsrec verilog tekhex binary ihex
make: *** [vex/mkrules.mk:23: build/Gearbots] Error 1
[error]: make process closed with exit code : 2
Has anyone seen anything like this before?
There were no highlighted errors in the program this was in the output after building
yes, the project location.
for some reason you are seeing the help for arm-none-eabi-objcopy, this usually happens when incorrect arguments are passed to it, just trying to figure out what that is.
you could also try editing the makefile and setting VERBOSE to 1, then build again and paste the output here.
So we will have to try the VERBOSE thing tomorrow… Where would the incorrect arguments be? Would those be in a build file or the main program? There were no errors throughout the main program that were highlighted; all braces and semicolons were accounted for, and I wouldn’t know what errors to look for in the build files.
clean project
rmdir /S /Q build 2> nul || :
[info]: build completed!
md "build/src" 2> nul || :
"CXX src/main.cpp"
clang -target thumbv7-none-eabi -fshort-enums -Wno-unknown-attributes -U__INT32_TYPE__ -U__UINT32_TYPE__ -D__INT32_TYPE__=long -D__UINT32_TYPE__='unsigned long' -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Os -Wall -Werror=return-type -fno-rtti -fno-threadsafe-statics -fno-exceptions -std=gnu++11 -ffunction-sections -fdata-sections -DVexV5 -Iinclude -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/include" -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/clang/8.0.0/include" -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/gcc/include" -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/gcc/include/c++/4.9.3" -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/gcc/include/c++/4.9.3/arm-none-eabi/armv7-ar/thumb" -c -o build/src/main.o src/main.cpp
"CXX src/robot-config.cpp"
clang -target thumbv7-none-eabi -fshort-enums -Wno-unknown-attributes -U__INT32_TYPE__ -U__UINT32_TYPE__ -D__INT32_TYPE__=long -D__UINT32_TYPE__='unsigned long' -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Os -Wall -Werror=return-type -fno-rtti -fno-threadsafe-statics -fno-exceptions -std=gnu++11 -ffunction-sections -fdata-sections -DVexV5 -Iinclude -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/include" -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/clang/8.0.0/include" -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/gcc/include" -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/gcc/include/c++/4.9.3" -I"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/gcc/include/c++/4.9.3/arm-none-eabi/armv7-ar/thumb" -c -o build/src/robot-config.o src/robot-config.cpp
"LINK SKILZ.elf"
arm-none-eabi-ld -nostdlib -T "C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/lscript.ld" -R "C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/stdlib_0.lib" -Map="build/Gearbots SKILZ.map" --gc-section -L"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5" -L"C:\Program Files (x86)\VEX Robotics\VEXcode V5 Text\sdk/vexv5/gcc/libs" -o SKILZ.elf build/src/main.o build/src/robot-config.o --start-group -lv5rt -lstdc++ -lc -lm -lgcc --end-group
arm-none-eabi-size SKILZ.elf
text data bss dec hex filename
10400 1108 1064588 1076096 106b80 SKILZ.elf
arm-none-eabi-objcopy -O binary build/Gearbots SKILZ.elf build/Gearbots SKILZ.bin
The options are:
relocations
listed in <file>
in <file>
section name
<commit>
<commit>
