The compiler tells us that there is a syntax error on line #9. We cannot seem to find any problems with the code that should cause this error. This is a screenshot of the code:Code screenshot.
You’re declaring variable “i” inside the for loop initializer. That’s not allowed in C (only C++). Take out the word “int” from that line, and add an “int i;” above it and it should work.
Actually I believe you will find the int i; needs to be at the very top, just inside the main() function. This is certainly the case with C18 and I believe EasyC is actually just a pretty front end to C18
Yes, that’s correct and what I meant, but I wasn’t very clear about where “above it” really meant.
EasyC is just a Drag and Drop front end for MCC18.
MCC18 is (mostly) ANSI 1989 compliant.
Declaring a Variable inside the For Loop (or any other place a Variable is Initialized, other than at the Very Top of the Scope) is not allowed. The Scope being differentiated by { and }.
C++ and (IRRC ANSI 1999) allow this usage for Variable Declaration…
For example, MCC18 will allow this because each Variable Declaration occurs at the top of a Scope:
int test_function()
int forty_two = 42;
forty_two++;
int ninety_nine = 99;
ninety_nine--;
int eighty_six = 86;
eighty_six += ninety_nine;
int thirteen = 13;
thirteen--;
Quill’s Code would need to be written like this:
#include "Main.h"
void accel(int targetVelocity)
int iC;
int i;
if(targetVelocity > 130)
for(i=127;i<targetVelocity;i+=20)
iC=127+(127-i);
SetPWM(5,i);
SetPWM(6,iC);
Wait(100);
or could be written like this:
#include "Main.h"
int iC;
int i;
iC=127+(127-i);
SetPWM(5,i);
SetPWM(6,iC);
Wait(100);
Qwill,
While you’re tuning your code, I suggest you correct the variable name spelling error in line 27.
Eric
