Unoffical Response to "Battery Voltage Detection?"
In ROBOTC, this is possible using the
nImmediateBatteryLevel
, for the main battery, and
BackupBatteryLevel
for the backup battery (the units are millivolts, IIRC).
As for the main part of your question:
While this is in theory possible, there’s a better way: using a control loop, like a PID. These were very popular last year in order to regulate flywheel speed. There are about a billion different implementations of PIDs in ROBOTC (even one implemented directly) , you should be able to find one to fit your needs.
Our team is using the LCD to display the battery levels. You can view the code at
https://github.com/vex-robotics/competition/blob/master/competition.c
Oh, thanks. I didn’t know that was a function I could use, though I already switched over to encoders instead, but thanks!
Also, for the power expander you can connect a sensor cable to the “Status” port on the power expander and read the analog value and interpret it as per the instructions on the wiki below
https://www.vexrobotics.com/wiki/Power_Expander
Code would be as follows:
float powerExpanderVoltage = SensorValue[statusPort]/70.0
Provided you are using a Revision A2 power expander
