Unofficial answer to "Zip ties on Chain Bar"
The use of zip ties is unrestricted for wire management but for the use as a replacement for links, it would be OK so long as you use the zip ties Vex sells as part of the Vex EDR system or one that are identical. They have two sizes and are used for lots of different things without restriction to include tightening chain. Just be sure to use the correct zip ties and you will be fine.
