- it’s not obvious, but the RobotC tech support channel is only answered by RobotC staff, and the community cannot respond to your request if you put it there.
- whenever you post code, please put opening and closing "
" tags around your entire program, or use highlight the text and press the </> button in the toolbar. People are more likely to help you if they can read your code easily.
See comments in code below, starting with "BLP" (BigLeslieP):
// BLP: you shouldn’t need this line; on my end, one can use abs(whatever)
// without having to define like this
#define abs(X) ((X < 0) ? -1 * X : X)
void driveStraightDistance(int tenthsOfIn, int masterPower) {
int tickGoal = (42 * tenthsOfIn) / 10;
//This will count up the total encoder ticks despite the fact that the encoders are constantly reset.
// BLP: why are you contstantly resetting the encoders? You should reset them once, here, before the while
// loop, just once each time you call this function
// per comments below, you’d delete this line
int totalTicks = 0;
int slavePower = masterPower - 5;
int error = 0;
// BLP: Normally Kp is a fraction, and one multiplies the error by Kp, but that’s just
// a technicality
int kp = 5;
// BLP: just setting them once here is fine
SensorValue[leftEncoder] = 0;
SensorValue[rightEncoder] = 0;
//Monitor ‘totalTicks’, instead of the values of the encoders which are constantly reset.
// BLP: change this to while(abs(SensorValue[leftEncoder]) < tickGoal)
while(abs(totalTicks) < tickGoal) {
//Proportional algorithm to keep the robot going straight.
motor[leftMotor] = masterPower;
motor[rightMotor] = slavePower;
motor[frontLeftMotor] = masterPower;
motor[frontRightMotor] = slavePower;
error = SensorValue[leftEncoder] - SensorValue[rightEncoder];
// BLP: as mentioned above, usually you multiply error by Kp
// BLP: I think this is where you are going wrong ; you want to set
// slavePower = masterPower + error/Kp, not add the adjustment to what
// the slavePower already is
slavePower += error / kp;
// totally skip this part; it's not needed in each iteration
wait1Msec(100);
// BLP: totally skip this step; not needed
totalTicks+= SensorValue[leftEncoder];
