Original post: PoE Elevator Code - ROBOTC Tech Support - VEX Forum
Do you have any pictures of what you are trying to code?
What do you mean you have designed this code at the bottom?
Please “Attach a file” with the full code that is on the robot (if there is more code than what you originally posted)
In the code you posted, when
going <= 100
and
SensorValue[limitSwitchTwo] == 1
and
SensorValue[sonarTwo] == 2
, you check to see if
SensorValue[sonarTwo] == 5
. It can’t be - you just checked that it was equal to 2.
You can use
code] insert code here (with no spaces inside the square brackets) /code]
to put your code in nicely. This is the code you posted in your other post on the official tech support channel (I’ve edited it so it has less nesting, and doesn’t do your LED things).
#pragma config(Sensor, dgtl1, limitSwitchOne, sensorTouch)
#pragma config(Sensor, dgtl2, limitSwitchTwo, sensorTouch)
#pragma config(Sensor, dgtl3, limitSwitchThree, sensorTouch)
#pragma config(Sensor, dgtl4, greenOne, sensorLEDtoVCC)
#pragma config(Sensor, dgtl5, greenTwo, sensorLEDtoVCC)
#pragma config(Sensor, dgtl6, greenThree, sensorLEDtoVCC)
#pragma config(Sensor, dgtl7, sonar, sensorSONAR_inch)
#pragma config(Sensor, dgtl9, sonarTwo, sensorSONAR_inch)
#pragma config(Motor, port2, motorOne, tmotorVex393_MC29, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
//*!!Platform Type: Natural Language PLTW !!*//
task main() {
int ok = 0;
int going = 0;
while (true) {
if (going <= 100 && SensorValue[limitSwitchOne] && SensorValue[sonarTwo] == 5) {
startMotor(motorOne, 12);
ok = ok + 1;
if (SensorValue[sonar] == 5) {
stopMotor(motorOne);
// flash leds
ok = ok - 1;
going = 0;
going = going + 1;
if (going <= 100 && SensorValue[limitSwitchOne] && SensorValue[sonarTwo] == 2) {
ok = ok + 1;
// flash leds
ok = ok - 1;
going = 0;
going = going + 1;
if (going <= 100 && SensorValue[limitSwitchTwo] && SensorValue[sonar] == 5) {
startMotor(motorOne, -12);
ok = ok + 1;
if (SensorValue[sonarTwo] == 5) {
// flash leds
ok = ok - 1;
going = 0;
going = going + 1;
if (going <= 100 && SensorValue[limitSwitchTwo] && SensorValue[sonarTwo] == 2) {
ok = ok + 1;
if (SensorValue[sonarTwo] == 5) { // THIS WILL NEVER HAPPEN
// flash leds
ok = ok - 1;
going = 0;
going = going + 1;
if (going <= 100 && SensorValue[limitSwitchThree] && SensorValue[sonar] == 5) {
ok = ok + 1;
if (SensorValue[sonarTwo] == 2) {
// flash leds
ok = ok - 1;
going = 0;
going = going + 1;
if (going <= 100 && SensorValue[limitSwitchThree] && SensorValue[sonarTwo] == 5) {
ok = ok + 1;
if (SensorValue[sonarTwo] == 2) { // THIS WILL NEVER HAPPEN
// flash leds
ok = ok - 1;
going = 0;
going = going + 1;
if (going > 100 && ok == 0 && SensorValue[sonarTwo] == 5) {
// flash leds
going = 0;
if (going > 100 && ok == 0 && SensorValue[sonarTwo] == 2) {
// flash leds
going = 0;
} // [end] while(true)
} // [end] task main()
