Does anyone know how to unregister/unbind a callback function from a button pressed event when done using it? Thanks!
That’s not possible.
Unofficial Response
I feel like there is a reason why callback functions are not used by the majority. You have very little control of what you can do, and that can also be bad in a situation in competition where time is of the essence. I would suggest avoiding callback functions (or events) as much as possible unless it is necessary.
Event based programming can be really useful and powerful, it just has to be used correctly and understanding the implications.
It wouldn’t make sense in a lot of cases to dynamically bind and unbind callback functions in a context such as a driver control program in robotics.
I honestly agree it can be useful (like possibly binding screen touched events onto the V5 Brain if thats an option) but I feel like programming the robot event’s use case is negligible, which is why events are almost never used in PROS (I don’t even think is an option) unless I am mistaken.
Thanks everyone for your input.
Most programming constructs can be used and abused. As @OscarMNOVA12 mentions, dynamically binding/unbinding callbacks would seem to be an abuse of an event-based programming model.
One could certainly make a case (as, I believe the Vex C++ API does) that Controller button press events can be handled by reasonable call-back functions.
One could certainly envision a call-back anytime one does polling. For example, OkapiLib makes use of an “isSettled” function to allow asynchronous movements. For example:
intakes.spin();
drivetrain.moveToAsync(somePoint);
while(!drivetrain.isSettled()) {
sleep(20);
intakes.stop();
lift.raise();
Might be expressed more event-y as:
intake.spinUntilObjectIngested(raiseLiftFunction);
drivetrain.doActionAtPoint(somePoint, releaseObjectFromLiftFunction);
Coding is as much about telling the computer what to do as it is communicating to other programmers (including future-self you) what should happen.
