Updated motor controllers with DC braking
I’d like to see the Vex motor controllers upgraded to support dynamic braking under program control. This would help prevent back-driving without requiring a full control loop to actively maintain a fixed position (see this thread for an example).
The Motor Controller 29 firmware could watch for a specific signal that isn’t a valid R/C pulse train (say, 50% duty cycle?) and enable DC braking.
It may already be electrically possible for the Cortex’s built-in 2-wire ports to do this with just a firmware upgrade, if there isn’t a lockout that prevents both halves of the H-bridge both from switching to the same rail.
In order to use this feature in software, there would have to be a new function added, since it doesn’t really fit anywhere on the -128…127 power spectrum already available.
Cheers,
  • Dean
This already exists its just not supported by any of the programming options.
we played around with it by plugging it into an Arduino and then sending a 200us single and sure enough the motors went into a “braking” mode
I think that if it was supported it would almost entirely eliminate the need for arm “reverses” and such.
goes to RobotC feature request thread
Scott.
Huh - I guess I need to read the product page (which I even linked to!) more thoroughly next time.
I agree that this should go to ROBOTC and EasyC as an enhancement request.
Cheers,
  • Dean
If, as we suspect, the NXP supervisor processor controls the motors then it may also require a firmware upgrade from IFI.
