We have started to attempt to update the firmware for the Clawbot, we are getting a not connected signal, as well as the ports are not being identified properly. Thanks for you help in advance
Make sure you’re not running the programming software at the same time you run the update software.
Thank you for your advice, all good here in that regard now
