mbrunn
March 15, 2012, 7:26am
#1
if there is a US nationals webcast, where can it be found?
I don’t believe the webcast is up yet because the qualification matches start tomorrow, but it will be here .
Brunn, I emailed you a link last night
Is the webcast supposed to be up? Because I can’t connect.
The webcast will start tomorrow morning with the qualification rounds (Friday 3/16) - they are still setting up today with registration this afternoon. Judge interview start tonight, but no field action until tomorrow.
who is Brunn? and i dont think that the link is up quite yet guys! sorry!
Can’t connect but check it out tommorow.
Thanks guys…
jake40
March 16, 2012, 7:01am
#10
Anybody know when the webcast will be up today?
mms://sargasso-3.arc.nasa.gov/create
Is think link working for anyone? The live feed should have already started and its not working for anyone at my school
jake40
March 16, 2012, 7:07am
#12
Nope its not working for me either …have the qualification matches started yet?
They were scheduled to start 17 minutes ago
mcops
March 16, 2012, 7:26am
#14
I am able to get the live stream but the quality is pretty bad. you have to download: http://www.videolan.org/vlc/
then go to media - open network stream. then paste the link above into it.
mcops
March 16, 2012, 7:32am
#15
this is working for me too now…
is there a place to check the rankings for nationals?:p:):)
no but i will do that thank you :)
So I am trying to use VLC like it says above and I was able to watch it earlier today but now I seem to be getting an error that I cant fix. I have tried everything that I can think of but it isn’t working.
Here is the error:
main debug: using interface module “macosx”
main debug: TIMER module_need() : 163.376 ms - Total 163.376 ms / 1 intvls (Avg 163.376 ms)
main debug: playlist threads correctly activated
main debug: rebuilding array of current - root Playlist
main debug: rebuild done - 0 items, index -1
macosx debug: using future AR cookies
main debug: looking for services probe module: 5 candidates
main debug: no services probe module matching “any” could be loaded
main debug: TIMER module_need() : 2.589 ms - Total 2.589 ms / 1 intvls (Avg 2.589 ms)
main debug: looking for extension module: 1 candidate
lua debug: Opening Lua Extension module
lua debug: Trying Lua scripts in /Users/jonathanleitschuh/Library/Application Support/org.videolan.vlc/lua/extensions
lua debug: Trying Lua scripts in /Applications/VLC.app/Contents/MacOS/share/lua/extensions
lua debug: Trying Lua scripts in /Applications/VLC.app/Contents/MacOS/share/share/lua/extensions
main debug: using extension module “lua”
main debug: TIMER module_need() : 0.209 ms - Total 0.209 ms / 1 intvls (Avg 0.209 ms)
macosx debug: Found 1 capture devices
macosx debug: no optical media found
main debug: adding item udp://' ( udp:// ) main debug: no fetch required for (null) (art currently (null)) main debug: rebuilding array of current - root Playlist main debug: rebuild done - 1 items, index -1 main debug: processing request item: udp://, node: Playlist, skip: 0 main debug: resyncing on udp:// main debug: udp:// is at 0 main debug: starting playback of the new playlist item main debug: creating new input thread main debug: Creating an input for 'udp://' main debug: using timeshift granularity of 50 MiB, in path '/tmp' main debug:
udp://’ gives access udp' demux
’ path `’
main debug: creating demux: access=‘udp’ demux=’’ location=’’ file=’(null)’
main debug: looking for access_demux module: 0 candidates
main debug: no access_demux module matched “udp”
main debug: TIMER module_need() : 0.215 ms - Total 0.215 ms / 1 intvls (Avg 0.215 ms)
main debug: creating access ‘udp’ location=’’, path=’(null)’
main debug: looking for access module: 1 candidate
access_udp debug: opening server=:0 local=:1234
main debug: net: opening any datagram port 1234
main debug: using access module “access_udp”
main debug: TIMER module_need() : 1.191 ms - Total 1.191 ms / 1 intvls (Avg 1.191 ms)
main debug: Using block method for AStream*
main debug: starting pre-buffering
main debug: adding services_discovery sap{longname=“Network streams (SAP)”}…
main debug: looking for services_discovery module: 1 candidate
main debug: using services_discovery module “sap”
main debug: net: opening 224.2.127.254 datagram port 9875
main debug: TIMER module_need() : 0.245 ms - Total 0.245 ms / 1 intvls (Avg 0.245 ms)
main error: cannot join multicast group: Can’t assign requested address
main debug: net: opening 239.195.255.255 datagram port 9875
main debug: net: opening 239.255.255.255 datagram port 9875
main debug: net: opening 224.0.0.255 datagram port 9875
main debug: net: opening ff02::2:7ffe%lo0 datagram port 9875
main debug: net: opening ff02::2:7ffe%gif0 datagram port 9875
main error: cannot join multicast group: Invalid argument
main debug: net: opening ff02::2:7ffe%stf0 datagram port 9875
main debug: net: opening ff02::2:7ffe%en0 datagram port 9875
main debug: net: opening ff02::2:7ffe%en1 datagram port 9875
main debug: net: opening ff02::2:7ffe%fw0 datagram port 9875
main debug: net: opening ff02::2:7ffe%p2p0 datagram port 9875
main debug: net: opening ff02::2:7ffe%ham0 datagram port 9875
Repeats 3 times
main debug: net: opening ff04::2:7ffe datagram port 9875
main debug: net: opening ff05::2:7ffe datagram port 9875
This is repeated several more times…
main: stopping playback
main debug: deleting item udp://' main debug: incoming request - stopping current input main debug: waitpipe: object killed main debug: dying input main debug: socket 13 polling interrupted main debug: prebuffering done 0 bytes in 114s - 0 KiB/s main error: cannot pre fill buffer main warning: cannot create a stream_t from access main debug: removing module "access_udp" main debug: dead input main debug: TIMER input launching for 'udp://' : 114814.977 ms - Total 114814.977 ms / 1 intvls (Avg 114814.977 ms) main debug: adding item
mms://sargasso-3.arc.nasa.gov/create’ ( mms://sargasso-3.arc.nasa.gov/create )
main debug: processing request item: mms://sargasso-3.arc.nasa.gov/create, node: Playlist, skip: 0
main debug: resyncing on mms://sargasso-3.arc.nasa.gov/create
main debug: mms://sargasso-3.arc.nasa.gov/create is at 0
main debug: Creating an input for ‘mms://sargasso-3.arc.nasa.gov/create’
main debug: using timeshift granularity of 50 MiB, in path ‘/tmp’
main debug: mms://sargasso-3.arc.nasa.gov/create' gives access
mms’ demux ' path
sargasso-3.arc.nasa.gov/create ’
main debug: creating demux: access=‘mms’ demux=’’ location=‘sargasso-3.arc.nasa.gov/create ’ file=’(null)’
main debug: no access_demux module matched “mms”
main debug: TIMER module_need() : 0.182 ms - Total 0.182 ms / 1 intvls (Avg 0.182 ms)
main debug: creating access ‘mms’ location=‘sargasso-3.arc.nasa.gov/create ’, path=’(null)’
access_mms debug: waiting for connection…
main debug: net: connecting to sargasso-3.arc.nasa.gov port 1755
main debug: connection succeeded (socket = 15)
access_mms debug: connection(tcp) with “sargasso-3.arc.nasa.gov:1755 ” successful
access_mms debug: generated guid: 0xbabac001-0xa3dd-0x7bb3-0xf0cb40d527dbf90d
access_mms debug: recv command start_sequence:0x00000001 command_id:0xb00bface length:128 len8:16 sequence 0x00000000 len8_II:14 dir_comm:0x00040001
access_mms debug: 0x01 --> server_version:“9.01.01.5001” tool_version:"" update_player_url:"" encryption_type:“NTLM”
access_mms debug: recv command start_sequence:0x00000001 command_id:0xb00bface length:80 len8:10 sequence 0x00000001 len8_II:8 dir_comm:0x00040002
access_mms error: no data received
access_mms warning: cannot fill buffer
access_mms warning: failed to receive command (aborting)
access_mms error: unknown answer (0x2 instead of 0x06)
access_mms debug: Connection closed
main error: Write error: Broken pipe
access_mms error: failed to send command
main debug: net: opening 192.168.0.196 datagram port 7000
access_mms debug: connection(udp) at “192.168.0.196:7000” successful
access_mms debug: generated guid: 0xbabac001-0xfaa6-0x556f-0xe1b4405c8ab508e9
access_mms debug: media file name/path accepted
access_mms debug: answer 0x06 flags:0x02000000 media_length:0s packet_length:1444 packet_count:0 max_bit_rate:349056 header_size:5509
access_mms debug: reading header
access_mms debug: recv command start_sequence:0x4a000001 command_id:0xb00bface length:40 len8:5 sequence 0x00000003 len8_II:3 dir_comm:0x00040011
access_mms warning: cannot receive header (1/10)
This repeats for 2 through 6
access_mms warning: cannot receive header (7/10)
access_mms debug: recv command start_sequence:0x4a000001 command_id:0xb00bface length:32 len8:4 sequence 0x00000004 len8_II:2 dir_comm:0x0004001b
