Usage of laser pointer
This isn’t specified in the manual, but is it legal to use a laser pointer for autonomous setup for the shooter??
There have been many Q&As about this before. Yes you can use a laser pointer before a match for alignment but not once the match starts but please remember to use a laser pointer safely and responsibly at competitions.
+1
The other thing to avoid is wasting too much time on the field.
Make sure you verify that the laser pointer doesn’t have an axial angle built in - ie don’t assume the laser beam is aligned perfectly and centered with the center of the pointer. I’ve had some people use a pointer in a manufacturing facility, and when the pointer was placed in a fixture and rotated, the beam rotated and traced out a circle. If it does, you won’t get repeatability in the targeting from event to event.
