This is my 3rd season with robotics, and luckily have had no problems until now. We recently updated to easyC V2.9.3.2 then 2.9.3.3 and Master Code 10 and the Prolific Driver PL2303 (I’m not sure about the #, but I think that is it.) I’ve tried this on 6 robots, with 3 orange cables and 4 computers all running XP. I’ve had the same scattered results described below with any/all combinations so I’ve eliminated a hardware problem.
Since then, downloading a program is a nightmare. On occasion it works without a problem, but this typically seems to be after reinstalling the driver and then rebooting. After being successful once it will not download again if the orange cable is unplugged or I have to reboot.
Usually, the easyC locks up after I being downloading the program. It doesn’t start erasing or writing the program. Alternatively, it will ask if the serial port is connected and if the power is on.
I’m trying to avoid reformatting the hard drives on 15 computers to start from scratch. Does anyone have any ideas that may be fix the issue or see a problem with compatibility?
Is it necessary to upgrade to Master code 10? I’m tempted to go back down to master code 9 and the older version of EasyC, but I don’t know if that will cause problems at competitions. Is a downgrade an option that may work?
A call to Intelitek resulted in the suggestion to redownload the master code and default program. I have yet to do this, but I’m thinking it won’t resolve my problem. I also read this thread
One problem is that I’m unable to run in administrator mode. I did have our IT guy come and login and do it though, with the same scattered results.
I’m obviously very frustrated and trying to be patient, but when we’re about to take 6 robots to 3 different competitions I can see the nightmare that awaits if I can’t get the issues resolved.
Thanks for any help in advance.
