Usercontrol Help
Can someone tell me what is wrong with our user control? We want the Intake to go out with tray when button b is pressed. the tray moves, but the intakes do not.
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
FL.spin(vex::directionType::fwd, (Controller1.Axis2.value()+Controller1.Axis1.value()), vex::velocityUnits::pct);
BL.spin(vex::directionType::fwd, (Controller1.Axis2.value()+Controller1.Axis1.value()), vex::velocityUnits::pct);
FR.spin(vex::directionType::fwd, (Controller1.Axis2.value()-Controller1.Axis1.value()), vex::velocityUnits::pct);
BR.spin(vex::directionType::fwd, (Controller1.Axis2.value()-Controller1.Axis1.value()), vex::velocityUnits::pct);
FL.spin(vex::directionType::fwd, (Controller1.Axis3.value()), vex::velocityUnits::pct);
BL.spin(vex::directionType::fwd, (Controller1.Axis3.value()), vex::velocityUnits::pct);
FR.spin(vex::directionType::fwd, (Controller1.Axis2.value()), vex::velocityUnits::pct);
BR.spin(vex::directionType::fwd, (Controller1.Axis2.value()), vex::velocityUnits::pct);*/
//The Tray goes out with Button B and in with Button A.
if (Controller1.ButtonA.pressing ()){
Tray.spin(directionType::rev, 100, vex::velocityUnits::pct);
  else if (Controller1.ButtonB.pressing()){
      Tray.spin(directionType::fwd, 100, vex::velocityUnits::pct);
      IntakeL.spin(directionType::rev, 30, vex::velocityUnits::pct);
      IntakeR.spin(directionType::rev, 30, vex::velocityUnits::pct);
  else{
      Tray.stop(brakeType::hold);
  if (Controller1.ButtonL1.pressing()){
      Lift.spin(directionType::fwd, 100, vex::velocityUnits::pct);
  else if (Controller1.ButtonL2.pressing()){
      Lift.spin(directionType::rev, 100, vex::velocityUnits::pct);
  else{
      Lift.stop(brakeType::hold);
  if (Controller1.ButtonR1.pressing()){
      IntakeL.spin(directionType::fwd, 100, vex::velocityUnits::pct);
      IntakeR.spin(directionType::fwd, 100, vex::velocityUnits::pct);
  else if (Controller1.ButtonR2.pressing()){
      IntakeL.spin(directionType::rev, 100, vex::velocityUnits::pct);
      IntakeR.spin(directionType::rev, 100, vex::velocityUnits::pct);
  else if (Controller1.ButtonDown.pressing()){
      IntakeL.spin(directionType::rev, 50, vex::velocityUnits::pct);
      IntakeR.spin(directionType::rev, 50, vex::velocityUnits::pct);
      FL.spin(directionType::rev, 20, velocityUnits::pct);
      BL.spin(directionType::rev, 20, velocityUnits::pct);
      FR.spin(directionType::rev, 20, velocityUnits::pct);
      BR.spin(directionType::rev, 20, velocityUnits::pct);
  else{
      IntakeL.stop(brakeType::hold);
      IntakeR.stop(brakeType::hold);
                // prevent wasted resources.
From what I see from your code.
WHEN this is runned!
What happens is the other if and else if and then else at the bottom that controls the intakes is messing it up.
else{
So basically it is constantly telling intakes too stop when you press button B because this else is not with that if, else if, else. Just add two else statements and fix your code up.
