Using Power Expander with V5
current is limited to 2A. Voltage is 5V. There is no PTC, the voltage regulator chip will shutdown if too much current is pulled. The VCS/VEXcode motor29 class has some slew rate code to help with current transients, the motor_victor and pwm_out classes drive without that. The V5 supports the old motors primarily for classroom use with lights loads.
