Using terminal to display motor position
I have this short code over here which I want to use to display a motor’s position to the terminal.
void printPos()
  while(true)
    printf("leftFront.position(degrees)\n");
    wait(1,seconds);
int main()
  vexcodeInit();
  printPos();
Of course, this just writes leftFront.position(degrees) in the terminal every second. However, when I try typing
void printPos()
  while(true)
    printf(leftFront.position(degrees));
    wait(1,seconds);
It gives me an error on printf, saying [clang] No matching function to call to ‘printf’.
tldr, how can I use the terminal to display my motor’s position?
Try
printf(“Left front position: %f”, leftFront.position(degrees));
Not sure if this will work but you can also try print();
Wow, I wasn’t expecting a solution this quick! Thanks! This is what worked:
void printPos()
  while(true)
    printf("Left Front Position: %f\n", leftFront.position(degrees));
    task::sleep(1000);
