Hello, im new to vex and i was assigned to do the autonomous phase for 2 robots. i made a set of functions that used one camera (called Vision19) and one ultrasonic (called *RangeFinderA) to track where the object is and move to it then lift it, and it worked!!, the problem is that i need to do the same method for 4 other cameras and ultrasonics so i changed the function from : void moveToObject() to moveToObject(vision camera, sonar ultrasonic, signature obj) and it completely broke the code even though its the same code.
the original code that works:
// Autonomus Phase
void VisionConfig() {
Vision19.setBrightness(55);
Vision19.setSignature(Vision19__YELLOW_GOAL);
bool is_close() {
if (RangeFinderA.distance(mm) < 40){
Brain.Screen.printAt(1, 60, “distance: %f cm”, RangeFinderA.distance(distanceUnits::cm));
return true;
return false;
bool find_object() {
//Brain.Screen.print(“trying to find object”);
//Brain.Screen.newLine();
Vision19.takeSnapshot(Vision19__YELLOW_GOAL);
while (Vision19.objectCount == 0) {
moveCar(0, 25);
if (Vision19.objectCount != 0)
return true;
return true;
return false;
bool is_lined() {
int screen_middle_x = 316 / 2;
if (Vision19.largestObject.centerX > screen_middle_x - 60 &&
Vision19.largestObject.centerX < screen_middle_x + 60 &&
Vision19.objectCount>0){
//Brain.Screen.print(“Lined”);
return true;
//Brain.Screen.print(“not Lined”);
// Brain.Screen.newLine();
return false;
void lining_up(){
//Brain.Screen.print(“lining up now i think”);
int counter=0;
while (not is_lined()) {
//Brain.Screen.print("lining up again, Counter: ");
//Brain.Screen.print(counter);
counter++;
// snap a picture
// did we see anything?
if (Vision19.objectCount>0) {
// where was the largest thing?
if (Vision19.largestObject.centerX < screen_middle_x - 60) {
// on the left, turn left
is_lined();
Brain.Screen.print(“Turning Right”);
moveCar(0, 35);
} else if (Vision19.largestObject.centerX > screen_middle_x + 60) {
// on the right, turn right
is_lined();
Brain.Screen.print(“Turning Left”);
moveCar(0, -35);
} else {
// in the middle, we’re done lining up
Brain.Screen.print(“Stop”);
is_lined();
moveCar(0, 0);
break;
} else {
// saw nothing, relax
Brain.Screen.print(“found nothing sorry”);
bool moveToObject() {
//#region config_init
VisionConfig();
// camera image is 316 pixels wide, so the center is 316/2
while (1) {
if (not is_close()) {
Brain.Screen.print(RangeFinderA.distance(mm));
if(find_object()){
if (not is_lined()) {
//Brain.Screen.print("not linedup anymore");
lining_up();
if (is_lined() && not is_close()&&
Vision19.objectCount > 0) {
//Brain.Screen.print("moving forwards");
moveCar(50, 0);
} else
if(delayAuto >10000){
moveCar(0,0);
Brain.Screen.print("DONE MOVING TO OBJECT THNKFULLY");
break;
screenClear++;
if(screenClear >=1000){
screenClear=0;
Brain.Screen.clearScreen();
Brain.Screen.setCursor(1,1);
delayAuto++;
return true;
int main() {
vexcodeInit();
setup();
moveToObject();
comp.drivercontrol(userControl);
while (true) {
// Keep the main program running.
wait(0.05, seconds);
then the code after adding argument and does not work:
// Autonomus Phase
void VisionConfig(vision camera ,signature obj ) {
camera.setBrightness(55);
camera.setSignature(Vision19__YELLOW_GOAL);
bool is_close(sonar UltraSonic) {
if (UltraSonic.distance(mm) < 40){
Brain.Screen.printAt(1, 60, “distance: %f mm”, UltraSonic.distance(distanceUnits::mm));
return true;
return false;
bool find_object(vision camera, signature obj) {
Brain.Screen.printAt(1, 100, “trying to find obj”);
camera.takeSnapshot(Vision19__YELLOW_GOAL);
while (camera.objectCount == 0) {
moveCar(0, 25);
if (camera.objectCount != 0){
Brain.Screen.printAt(1, 120, "obj found");
return true;
return true;
return false;
bool is_lined(vision camera, signature obj) {
if (camera.largestObject.centerX > screen_middle_x - 60 &&
camera.largestObject.centerX < screen_middle_x + 60 &&
camera.objectCount>0){
Brain.Screen.printAt(1, 140, " lined up");
return true;
Brain.Screen.printAt(1, 160, “NOT lined up”);
return false;
void liningUp(vision camera2){
Brain.Screen.printAt(1, 20, “function LiningUp”);
int counter=0;
while (not is_lined( camera2, Vision19__YELLOW_GOAL)) {
counter++;
// snap a picture
camera2.takeSnapshot(Vision19__YELLOW_GOAL);
if (camera2.objectCount>0) {
if (camera2.largestObject.centerX < screen_middle_x - 60) {
is_lined( Vision19, Vision19__YELLOW_GOAL);
Brain.Screen.printAt(1, 180, “Turning Right”);
moveCar(0, 35);
} else if (camera2.largestObject.centerX > screen_middle_x + 60) {
Brain.Screen.printAt(1, 180, “Turning Left”);
moveCar(0, -35);
} else {
// in the middle, we're done lining up
Brain.Screen.printAt(1, 180, "Done lining up");
moveCar(0, 0);
break;
} else {
Brain.Screen.printAt(1, 180, "found nothing");
bool moveToObject(sonar Ultrasonic,vision camera,signature obj) {
VisionConfig(camera,Vision19__YELLOW_GOAL);
while (1) {
if (not is_close(Ultrasonic)) {
Brain.Screen.printAt(1, 60, "distance: %f cm", RangeFinderA.distance(distanceUnits::cm));
if(find_object(camera,Vision19__YELLOW_GOAL)){
Brain.Screen.printAt(1, 200, ": obmoveToObjectject found");
if (not is_lined( camera, obj)) {
Brain.Screen.printAt(1, 200, "moveToObject: its not lined liningUp");
liningUp(camera);
if ( is_lined( camera, obj) && not is_close(Ultrasonic)&&
camera.objectCount > 0) {
Brain.Screen.printAt(1, 200, "moveToObject: LinedUp moving forwards");
moveCar(50, 0);
} else
if(delayAuto >= 100){
delayAuto =0;
moveCar(0,0);
break;
screenClear++;
screenClear=0;
delayAuto++;
return true;
int main() {
vexcodeInit();
setup();
wait(1,seconds);
moveToObject(RangeFinderA,Vision19,Vision19__YELLOW_GOAL);
while (true) {
// AutoMoveCar();
// obj_in_center();
the problem im getting with the second code is that the car never finds the object so it just spins around forever even though the screen prints (object found) after the camera detects the object
ps. some part from the second code might differ from the original because of trail and error of me trying to fix it
