using V1 rack gears with the new sliders?
We literally just realized V2 racks is a thing like 20 minutes ago… is there anyways to work around it?
@4043c What do you mean work around it? They are very similar, just better for HS situations. They have 8-32 holes instead of 6-32 and use plastic molded inserts over brass, but this is an easy change to make by just swapping the screw size. Otherwise its the same.
@ethan_matlack huh, I’ll upload a picture, the description on the store page its only compatible with the v2 racks so i assumed that’s why :P. in that case could you please point out what i did wrong here?
https://drive.google.com/file/d/0B1dPrjem8RRdNjY4ZUxZYWJJOW8/view?usp=sharing
its abit hard to see, but the srews are hitting each other, thus prevent them from sliding through.
https://drive.google.com/open?id=0B1dPrjem8RRdRUVFSF9Md2ppaTQ
The plastic parts have smaller holes so you can tap your own threads just by screwing screws in. You dont need to go all the way through and use a nut. Just use smaller screws and screw down from the top.
Ah, I believe you’ve confused two different parts. The parts you’ve posted a picture of is technically a “linear slide” component, not to be confused with the new V2 rack. As @Sirchiggins101 said, just use the shortest 8-32 screws and tap into the plastic. It’s annoying, but the only way to avoid collision.
I see, thx mates
