Using VCS syntax in Pros
I’ve been trying to switch from VCS to Pros but I was wondering if there was a way I could keep my VCS code without having to change syntax to the PROS c++ syntax? Thanks.
No you have to change everything to use the PROS C++ API.
You could always switch the VEXcode if you want a more full featured editor, that will import the VCS program without needing to change it.
