Using VEX controller as game pad
I have no idea if this is possible, but is there a way to connect the VEX controller to a computer and use it as a gamepad?
It’s technically not impossible, but there are no drivers or software so it does not work. It’s much easier to use a cheap Logitech.
I remember hearing that you can use the xbone controller drivers and trick your computer into thinking that a Dualshock 4 is an xbone controller, although I’m not sure how difficult it is. If you can find out how that works, that might be a good start.
That’d be DS4Windows.
The VEX Joystick uses some really proprietary stuff, I recently took a logic analyzer to it and found some really REALLY strange interactions between the Joystick and the VEXnet keys.
Which this stupid forum won’t post. Oh well probably for the better.
This is somewhat unrelated, but uh, are there more posts on this thread than I can’t see? It says there are 8 posts, but I only see 4. Am I the only one having that problem?
Yes, I have that issue too.
