V5 and crossover cables?
@Paul Copioli What would happen if someone accidentally used an RJ11 crossover cable in the V5 system? (ignore the RJ11 part in the pic below) Do you have a diagram for us yet?
Excellent question.
To my best knowledge, the pinout is as follows:
  1. RS-485 A
  2. RS-485 B
  3. Power
  4. GND
So if you manage to get a RJ11 crossover cable somewhere (or actually made one yourself, that’s much more likely occurence) and use it, you should still be good - as in, it won’t work, but nothing will burn.
RS-485 inputs need to be very resilient and high-enough input impedance anyway, so power into one of them is no big deal (the chips I have seen used survive ±70V, besides 16kV static discharge).
RS-485, when signalling logical one over crossover cable would effectively put about 3V reverse voltage on the power pins, something I bet VEX design deals with properly too.
