V5 Code Not working
My team needs help with our code. Our brain downloads it and whenever we change the program to the autonomous code, it runs a different program. We can’t seem to figure out the problem other than the brain misidentifying the code. If anyone has a solution, please tell me.
This sounds like you are pressing drive on the controller. You actually need to go to the right and click programs then select your program. If this is not the issue that you are having and you are selecting the right program, you should upload your code so we can better help you.
I had an issue with my code not updating after downloading it. I fixed the problem by restarting my computer but you should make sure all of your motors are in the right ports. I have learned from experience if 1 or 2 motors are in the wrong port or not updated it can cause a mess.
