Issue:
The inertial sensor drifts by about 3 degrees after every full rotation.
Testing Setup:
- I have secured 4 V5 Inertial Sensor - VEX Robotics on my robot. The screws are finger tight and the sensors do not move around. The sensors are placed on parts of the chassis that do not move.
- All 4 sensors are laid flat on the robot pointing in the same direction.
Inertial18
is placed in the center of the robot.Inertial11
is placed at the front right.Inertial14
is placed at the rear right.Inertial20
is placed at the rear left. - One of the sensors,
Inertial14
has been factory recalibrated on a spirit level. -
Inertial11, 14, and 20
are brand new.Inertial18
has been used in a few competitions before. - The heading values are printed on the robot screen every 20 milliseconds.
Testing:
I placed the robot’s left side against a straight edge then calibrated all sensors.
Immediately after calibration, the values reported are as follows
Inertial11: 0.185
Inertial14: 0.090
Inertial18: 359.953
Inertial20: 0.053
I waited 60 seconds, and the values reported are:
Inertial11: 359.697
Inertial14: 0.344
Inertial18: 0.597
Inertial20: 359.832
Inertial11 Error: -0.303, Minute Drift: -0.488
Inertial14 Error: 0.344, Minute Drift: 0.254
Inertial18 Error: 0.597, Minute Drift: 0.644
Inertial20 Error: -0.168, Minute Drift: 0.221
These values are fine and shows that the sensor drifts only by about 0.2-0.6 degrees over a minute.
Using my hands, I slowly rotated my robot clockwise by 360 degrees. The rotation process took about 3 seconds and I kept the robot level during the rotation. I then realigned the robot on the straight edge to ensure the same heading as when calibrated. The values reported are:
Inertial11: 356.957
Inertial14: 357.220
Inertial18: 358.161
Inertial20: 359.660
Inertial11 Error: -3.043, 1st Rotate: -2.740
Inertial14 Error: -2.780, 1st Rotate: -3.124
Inertial18 Error: -1.839, 1st Rotate: -2.436
Inertial20 Error: -0.340, 1st Rotate: -0.172
Sensor 20 has an acceptable value with error of 0.34 degrees and the rotation only changed the heading by 0.172 degrees.
However, all the other sensors are now off by more than 1 degree.
I manually rotated my robot clockwise by another 360 degrees. The values reported are:
Inertial11: 354.760
Inertial14: 354.407
Inertial18: 355.485
Inertial20: 0.211
Inertial11 Error: -5.240, 1st Rotate -2.740, 2nd: -2.197
Inertial14 Error: -5.593, 1st Rotate: -3.124, 2nd: -2.813
Inertial18 Error: -1.839, 1st Rotate: -2.436, 2nd: -2.676
Inertial20 Error: -0.340, 1st Rotate: -0.172, 2nd: 0.551
Sensor 20 still has a great reading, however, the other ones are off by about 1-5 degrees now.
Finally, I rotated my robot another 360 degrees clockwise. The values now are:
Inertial11: 352.614
Inertial14: 351.730
Inertial18: 353.406
Inertial20: 0.960
Inertial11 Error: -7.386, 1st Rotate -2.740, 2nd: -2.197, 3rd: -2.146
Inertial14 Error: -8.270, 1st Rotate: -3.124, 2nd: -2.813, 3rd: -2.677
Inertial18 Error: -6.594, 1st Rotate: -2.436, 2nd: -2.676, 3rd: -2.079
Inertial20 Error: 0.960, 1st Rotate: -0.172, 2nd: 0.551, 3rd: 0.749
With sensor 14 off by 8.3 degrees.
The results show that every time Inertial11
rotates, it is off by -2.1 to -2.7 degrees, for Inertial14
it is -2.6 to -3.1, for Inertial18
it is -2.0 to -2.4 and for Inertial20
it is -0.172 to 0.749.
This has a heavy impact over the course of a 60 second autonomous period as the robot makes multiple turns, causing about 10-15 degrees of error towards the end of the program.
Is there a way to ensure the inertial sensors read more accurately?
