v5 Motor disconnects
Just a heads up. One of our new motors loses connection if the cable moves. There is a small amount of play in the cable connection and for most motors this is not a problem. For one it causes a disconnect of the motor (even if the tab is lifted). Swapping cables, the issues follows the motor. It is most likely a slightly different angle to the internal connection pins. I just though I’d give others a heads up that you should test putting a slight tension on the cable and see if the motor loses connection.
