Can I print the data of the automatic race to this place? I want to be able to check whether the distance and turning degree of the automatic race are correct
Yes, if you print to stdout (using printf
or std::cout
) it will show up in the “terminal” tab, provided that the brain or controller is plugged into your computer.
https://www.cplusplus.com/reference/cstdio/printf/
https://www.cplusplus.com/reference/iostream/cout/
You can also print text to the brain screen, that way you don’t need to be connected to a computer to see the debug output.
Yes, you can do:
std::cout << "Insert your message here";
This will make whatever text you put in the quotes print under the terminal tab.
Also, make sure that you include <iostream>
at the top of the file:
#include <iostream>
Keep in mind that this will only work if your brain/controller is connected to your computer.
