V5 rotation sensors
Hey I am having an issue with the rotation sensors and there is no references online so if you can help my code is below. I used this code for quads and it was fine until I changed it from quads to rotation sensors.
vex::rotation EncoderLeft = vex::rotation(vex::PORT18);
vex::rotation EncoderRight = vex::rotation(vex::PORT14);
void drivewintakes(double rotations, double intakesvalue){
Intake1.setVelocity(20, percentUnits::pct);
Intake2.setVelocity(200, percentUnits::pct);
Indexer1.setVelocity(intakesvalue, percentUnits::pct);
Intake1.spin(directionType::rev);
Intake2.spin(directionType::rev);
Indexer1.spin(directionType::fwd);
while(EncoderLeft < rotations && EncoderRight < rotations){
LM1.spinFor(-1*rotations, turns, 50, velocityUnits::pct,false);
LM2.spinFor(-1*rotations, turns, 50, velocityUnits::pct,false);
RM1.spinFor(rotations, turns, 50, velocityUnits::pct,false);
RM2.spinFor(rotations, turns, 50, velocityUnits::pct);
task::sleep(50);
Intake1.stop();
Intake2.stop();
Indexer1.stop(brake);
LM1.stop(coast);
LM2.stop(coast);
RM1.stop(coast);
RM2.stop(coast);
task::sleep(50);
Intake1.stop();
Intake2.stop();
LM1.stop(coast);
LM2.stop(coast);
RM1.stop(coast);
RM2.stop(coast);
Error: Invalid operands to binary expression
Formatted Code:
task::sleep(50);
Intake1.stop();
Intake2.stop();
LM1.stop(coast);
LM2.stop(coast);
RM1.stop(coast);
RM2.stop(coast);
task::sleep(50);
Intake1.stop();
Intake2.stop();
LM1.stop(coast);
LM2.stop(coast);
RM1.stop(coast);
RM2.stop(coast);
What line does it give you the error for?
Please mention how to format code when you do this.
OP, you can format code by putting ``` above and below the text you want to format.
This is the code that give the error
EncoderLeft is the name of the sensor. It doesn’t return a value since it isn’t a method. You would have to say something line EncoderLeft.rotations() in order for it return a value.
after that it says that there no member named in vex::rotation
In that case, use EncoderLeft.value();
use position() method. API is here
https://api.vexcode.cloud/v5/html/classvex_1_1rotation.html
