With the V5 system are you allowed a slave controller, if so does it also use a V5 controller? How do they sync or do you still use a cable between them?
Correct. There is no Partner Controller as before with the V5 System. To use two drivers, simply connect two V5 Controllers through the ports located at the top of the controller with a V5 Smart Cable.
