So, the mechanical guy is trying to do some basic V5 Text coding- some success, lots of frustration. In the tele-op file below I have successfully programmed the drive motors to the joysticks and another motor to run at reduced speed as commanded by buttons L1 and L2. So far so good. Progress stalled when I tried to command a fourth motor to a fixed number of rotations and a fith motor to limited torque. I’m obviously missing something. Help!
/ Module: main.cpp /
/ Author: C:\Users\Tom /
/ Created: Tue Dec 31 2019 /
/ Description: V5 project /
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Motor5Arm motor 5
// Motor6Claw motor 6
// Controller1 controller
// Motor3Feeder motor 3
// Motor4Launcher motor 4
// Motor1Left motor 1
// Motor2Right motor 2
#include “vex.h”
using namespace vex;
int main() {
vexcodeInit();
while(1==1){
//Everything between these curly braces will run in a continuous loop
//The following section controls drive motors via the joysticks
Motor1Left.setVelocity(Controller1.Axis3.value(), velocityUnits::pct);
Motor2Right.setVelocity(Controller1.Axis2.value(), velocityUnits::pct);
Motor1Left.spin(forward);//Set drive motor spin direction, one side will be reversed
Motor2Right.spin(forward);//Must be “forward”, changing to “reverse” makes motor quiver
//The following will run Motor3 at 1/4 speed controlled by shoulder buttons L1 & L2
//Maximum motor torque is still available
if(Controller1.ButtonL1.pressing() == true)
{Motor3Feeder.setVelocity(15, percent);}
else if(Controller1.ButtonL2.pressing() == true)
{Motor3Feeder.setVelocity(-15, percent);}
else
{Motor3Feeder.stop();}
//THIS COMMAND DOES NOT YET WORK; MOTOR RUNS AT HALF SPEED
//HALF SPEED MOTOR OPERATION IS THE DEFAULT WITH ONLY MOTOR & CONTROLLER CONFIGURING
//THE BRAIN IS APPARENTLY IGNORING THE CODE SHOWN
//This section commands the motor to turn +/-2 turns per Buttons R1 & R2
// Set the current position of the Launcher at zero
//Motor4Launcher.spin(forward);
//Motor4Launcher.setPosition(0, degrees);
if(Controller1.ButtonR1.pressing() == true)
{Motor4Launcher.spinFor(forward, 2, turns);}
else if(Controller1.ButtonR2.pressing() == true)
{Motor4Launcher.spinFor(reverse, 2, turns);}
else
{Motor4Launcher.stop();}
//This section commands the motor to turn at a low torque
if(Controller1.ButtonX.pressing() == true)
{Motor5Arm.setMaxTorque(10, percent);}
if(Controller1.ButtonB.pressing() == true)
else
{Motor5Arm.stop();}
