V5 Vision Sensor Connection to web based VexV5
I am trying to connect the old vision sensor (not AI) to the web version of Vex V5. Is this possible? I am getting no compatible devise found. Same if the usb connection is in the vision sensor or into the bot.
Any help is appreciated
What are you clicking when selecting devices? Because the regular sensor has a different option, it could be that
Works fine when using the desktop version v4
The old VEX Vision Sensor doesn’t work with the web version of VEX V5. Use the desktop version of VEXcode V5, update the sensor’s firmware, and connect it to the V5 Brain via a smart port for proper functionality.
