We built a drive train with 4 v5 motors but cant get all 4 to work at the same time. only 1 motor from each side will work at a time. Any suggestions on how to fix this with coding studio???
We can’t help you unless you post the code
- dont use vex coding studio.
- are you using the default clawbot code?
Are you using the default drive program to try and get the motors to move, when I first started 2 months back I also had a similar issue with figuring out how to get all 4 to move. You have to wire them on 1-2, 9-10, in order the default drive program to work.
I think it’s because the clawbot program uses only 2 motors 1 per side
No the default driver control program allows a 4 motor drivetrain to be controlled.
That’s correct. Open it up and look at where the motors should go. All of the buttons map to a port as well.
Thanks for the advice we will make sure to try that
Oh it’s different for the v5 clawbot? The legacy clawbot only uses 2 motors
No the default drive program is just the run button the V5 screen
