V5RC Hub skills errors in scoring calculator
Hello, I’ve discovered a few errors in all scoring calculators for Push Back in the V5RC Hub App:
  • In both match calculators, the number of blocks scored in the goals have a hard cap (15 for long goals, 7 for center goals), while the maximum number of blocks for all goals has been removed in V0.2 ov the game manual. It’s possible (although very hard and unlikley) to score more blocks in the goals.
  • Simillarly, in the skills match calculators, the number of scored blocks is hard capped at 44, but according to “Teams will receive points for all Scored Blocks, regardless of color.”. So the maximum number of blocks scored should be 61 for V5RC and 86 (Possibly 100) for VURC.
Hopfully I’ve posed this in the right place lol
How are you obtaining this number. I can’t see how you can score that many blocks. I could see +1 per goal, but not… whatever amount per goal.
It’s just the number of cubes avalable in skills. For V5RC there’s no match loads, with one preload + 60 cubes on the field. VURC has 100 cubes avalable because it’s the same setup as VURC head to head matches, however the blue matchloads and preloads might not be avalable (I’m gonna post a QnA when my teams officialy registered).
There are a few creative ways of scoring extra cubes, idk what the absolute maximum is, but the point is that it’s not explicitly defined, and the app especialy shouldn’t have it capped at 44 which is only the amount of cubes for each alliance.
Also, apologies for the typos. I meant to remove “skills” from the title, and RSC2a is the rule referenced in the second bullet point.
