(VAIC) FLIR Camera cannot show the robot position
Why can’t the FLIR camera be turned on, have you encountered this problem?PXL_20201215_101840146 PXL_20201215_101644044
Does the other system work ? Have you tried swapping cameras and/or usb dongles ?
Photo on 12-29-20 at 4.26 PM
Do you know where this goes into the Jetson Nano? I couldn’t find it in the manual
^the bigger chip…
That’s just a passive adapter for Micro SD to standard SD. Not used with Jetson Nano.
Thanks for your reply. I found it was connection problem of FLIR camera and Intel depth camera. These cameras should connect together at the same time to let the FLIR camera works.
