VCS C++ Pro Line Sensor in auton issues
I’ve been using a pair of line sensors to detect when balls have reached certain points for our intake and launcher. They have been relatively successful in driver control, but once I attempted to use them in auton they started behaving strangely. The logic I used in driver to associate a threshold in relation to what the sensors were reading no longer worked. I started a new program, and just printed the numbers that the sensors were reading to the brain screen. However, once I attempted to use those numbers in a logic statement they no longer contained a value (or at least I’m assuming so, the values still printed as expected but the logic statement did not respond to those variables). I’ll post the code below:
void autonomous( void ) {
while(true) //extended loop for testing
Intake.spin(directionType::fwd, 25, velocityUnits::pct); //turn on intake at slow speed to show no ball
while(puncherSense.value(vex::percentUnits::pct) > 45)   //is being picked up
    vex::task::sleep(20); //release resources
Intake.stop();
Fixed. The ball was moving too fast past the sensor, so the readings weren’t around for long enough to be used. Changing the loop speed and slowing down the intake showed expected results.
