VCS on Linux?
Hello, is there a supported way to run Vex Coding Studio on Linux?
Nope. Use PROS instead if you need Linux support.
I’d imagine you’d run into issues with the push procedure, but the majority of VCS is actually nwjs (basically html+css+javascript) which means you could theoretically run it on Linux distributions
You’d be better off using PROS
