Vcs program
welcome to join here to give some idea to another.
What?
when i turn the controller to left, the robot will turn right. it is program or robot setting wrong???
You most likely have your axis’s inverted in code. Post that section of your code here, please.
Also, when you start a post, put your question or idea in the title or description
can I delete one program in the robot box ? Each time when I use setting.delete program , I need to delete all . can I only delete one?
no, but you can download a new one to the same slot/position and it will delete it and add the new one
our robot is move for two motor , can I set those motor use 80 pct ?
You can use setVelocity
https://help.vexcodingstudio.com/#cpp/namespacevex/classvex_1_1motor/setVelocity
RightMotor.setVelocity(50, velocityUnits::pct);
I am mean in the controller setting
can I set the motor to run only 80 pct, in the controller setting
Please post your code…
