Vertical Expansion Clarification: SG5
I am looking at adding a vertical c-channel that flips up on a hinge to block discs and I have a few questions. SG5 a) states “The Robot must not be contacting the gray field tiles in either Low Goal.” Does this mean that I would have to lower it to intake discs in the low goal? Also, when it flips up it will break the rules momentarily before it is all the way extended. Is this illegal? Last question, can the c-channel start extended or do I have to have it flip up after the match starts like I have planned?
Yes, you would have to lower your blocker to go into the low goal and intake disks
Yes, this is illegal, because while it is flipping up, it does not fit within the 2" vertical tube. You would need something that extends vertically.
You need to fit within the starting 18 x 18 x 18 size requirements at the start of each match, so you would need to flip it up after the match starts.
