Mason
#1
Can anyone assist me on why this is running an infinite loop
void driveForward(double value ) {
while ( value <= 1){
value = value *0.082;
LM1.spin(vex::directionType::fwd, 80, vex::velocityUnits::pct);
LM2.spin(vex::directionType::fwd, 80, vex::velocityUnits::pct);
RM1.spin(vex::directionType::rev, 80, vex::velocityUnits::pct);
RM2.spin(vex::directionType::rev, 80, vex::velocityUnits::pct);
LM1.stop(vex::coast);
LM2.stop(vex::coast);
RM1.stop(vex::coast);
RM2.stop(vex::coast);
Mason
#2
the value was .01 at the bottom so it isnt that
Is value a double or an integer?
Also you have an unmatched bracket at the end, assuming it’s not connected to something else.
What value are you using when u call the function?
Work out the math.
Assume value starts at 1 or less. We’ll choose 1 for the example.
Is 1 <= 1? Yes, so run the loop. Change value to value * 0.082, so 1 * 0.082 = 0.082.
Is 0.082 <= 1? Yes, so run the loop. Change the value to value * 0.082, so 0.082 * 0.082 = 0.0064…
Is 0.0064 <=1? Yes…
You wrote a condition and loop that will never result in the condition being false if it is ever true once.
Mason
#7
Ok thanks for the suggestion ill try to work it out
