VEX AI - Does the Jetson Nano come with an SD card slot?
So today the package for the VEX AI competition arrived, while i was assembling it i noticed that the jetson nano was supposed to have a SD card slot but there was no SD card slot available on the device, is there supposed to be a sd card slot that came with the starter materials for this kit? How do i connect my sd card to the jetson nano?
It has an sd card slot, albeit it is a bit hidden. Check the rear of the device under the processing unit (on the side opposite the I/O)
It’s a bit hidden for sure…
Screen Shot 2020-09-14 at 4.19.36 PM
I would suggest popping in the SD card when you install the WIFI module. The slot is located on the back of the CPU board and will be easy to reach when it’s removed from the breakout board.
