VEX Base Plate Pack
A new VEX Structure Product has been released, the VEX Base Plate Pack.
P/N: 276-1341 - $29.99
VEX Base Plates are designed to serve as a foundation on which to build a robot. Use them to create a large stationary robotic arm, or interlock them to build larger manufacturing type systems. These pieces can also be used as large structural pieces in other robotic applications.
(2) Base Plates included
15-holes wide x 30-holes long
Made from cold rolled steel, 0.046" thick, zinc plated.
thank you vex for coming up with new (affordable) products :slight_smile:
it is also cheap enough to get and cut/bend into custom parts
is there an aluminum version coming any time soon? :wink:
It looks a lot more intended for stationary robot mechanisms rather than competition robots. This doesn’t really seem to have an obvious use for a VRC robot…
